Oil Filters 4wd vs. 2wd
Old Jul 10, 2008 | 12:10 PM
BlazerSS's Avatar
BlazerSS is an unknown quantity at this point
Default Oil Filters 4wd vs. 2wd
Okay I have an interesting question. Is there any harm in using a bigger 4wd oil filter on a 2wd truck? I have used both and haven't seen a difference in oil pressure, etc. but just want to make sure with the experts before I purchase another 4wd filter for my 2wd beast. I figure that since they cost the same, why not get the 4wd one which is longer with more filter media.
thanks
Old Jul 10, 2008 | 12:13 PM
Default RE: Oil Filters 4wd vs. 2wd
If it screws on and seals, it'll work.
I used to use the 4.3L oil filter on my Bonneville with the L67 supercharged 3.8L v6.
Old Jul 10, 2008 | 01:03 PM
rriddle3's Avatar
X2.
I use the larger Wix filter on my 2wd. More media = more filtration.
Old Jul 10, 2008 | 06:56 PM
BlazerSS's Avatar
I wasn't sure if, and forgive my ambiguous description, the threaded oil pressure valve (the cylinder the oil filter threads on to) is longer on a 4wd than a 2wd or not. I guess I was concerned that if it is and I'm using a longer filter on a 2wd truck then the oil isn't circulating and filtering properly and affecting the pressure. Does anyone know for fact by owning both a 2wd & 4wd 4.3L mpfi if the sending cylinders are the same length?
Old Jul 10, 2008 | 07:33 PM
I'm not sure what it is specifically that you are concerned about, but if the filter threads on and the seal, well, seals, then it will work.
TFisher
Jan 18, 2013 02:32 PM
step66
Jun 9, 2012 06:47 PM
gmbwrenchn
Jun 28, 2009 09:57 AM
swartlkk
May 11, 2008 09:08 PM
magtec
Aug 30, 2007 06:45 AM
