oil and fuel filter
Old Dec 7, 2009 | 03:54 PM
chris12018920's Avatar
chris12018920 is on a distinguished road
Default oil and fuel filter
Hey,
I have a 2002 blazer.I am going to change my oil, oil filter and fuel filter. is there anyting that i need to do(fill the filters or anything) before i do the changes
Old Dec 7, 2009 | 04:29 PM
86Blazer327's Avatar
86Blazer327 is an unknown quantity at this point
Fill the oil filter and make sure the o ring off the old oil filter isnt stuck to the block before you put the new one on
Old Dec 7, 2009 | 08:01 PM
thanks 86
but does anyone know if i need to do anything to the fuel filter??
Old Dec 7, 2009 | 08:04 PM
Nope . Should be an inline filter. Just put a wrench on the filter to hold it while you break the line nut loose so you dont wad the fuel lines up. Fuel pump will re prime the system when you have the new one on and hit the key
Old Dec 7, 2009 | 08:09 PM
BTW Squeeze the tabs together on the other end after you get the line loose and it should come off pretty easily.
Old Dec 7, 2009 | 08:10 PM
well thanks again 86
Old Dec 7, 2009 | 08:35 PM
Glad I could help.
latunguley
Nov 17, 2014 09:15 PM
95jblaze
Aug 27, 2011 03:46 PM
subarugt06
Mar 6, 2011 11:21 AM
FoxTrota
Aug 13, 2008 07:24 AM
shooter2499
Feb 4, 2008 09:23 PM
