Oil Leak
Old Jul 15, 2020 | 07:55 PM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
Does the oil that is leaking start at the valve cover?
On the passenger side I can't think of anything other the valve cover that could cause a leak.
But, at the back of the block there where the distributor goes in and the oil-pressure sensor that could be leaking. And there could be a leak at the rear end of the intake I guess.
Based on what you've reported, my bet would be the oil pressure sensor. Of course being back against the firewall, inspecting it sucks. LOL
You are on to something here. There is oil up under the distributor and I did have to put a new distributor in it. I have a bore scope and can look around a little in there and will do more tomorrow. For now the VC is buttoned back up and all parts and bolts are back in place, no leftovers. Is it possible that it's coming from under the distributor? Could I have some something wrong under there?
Old Jul 15, 2020 | 08:17 PM
I can't remember for sure, but I think there should be a gasket for the distributor.
Old Jul 15, 2020 | 08:23 PM
It has something, I'm thinking it was an O-ring but something makes me think I'm about to get a refresher course.
Old Jul 15, 2020 | 08:34 PM
Start at TDC! lol... I hate reinstalling the distributor...
Old Jul 15, 2020 | 11:21 PM
Yes, whatever you do, do not let the crankshaft turn!
What I learned for putting my distributor back in was to use a Sharpie to mark the direction it was pointing. If It goes in at about 30 degrees off, then the top of the oil pump driveshaft is likely rotated too far preventing it from engaging the correct teeth on the camshaft gear. The fix is to take a long flat-blade screw-driver and turn back the oil-pump drive shaft a tad and try to drop it in again. It might take a couple tries.
Old Jul 16, 2020 | 10:00 AM
I think I got it and I'm not happy to say that I now have enough experience with the distributor to make it fairly easy. When I did the first one I somehow got the oil pump drive knocked out of position and it took quite a while to get it right. My head won't fit in there and I had to use the bore scope so I could even see the slot and get screwdriver into it. Well...when I swapped the core out for a new distributor at NAPA we just took the new one out of the box and put the old one in the box and I didn't get a gasket. I didn't recall seeing one on the removed unit either. I looked at it during installation and figured that with the location and size of the pieces, it didn't need a gasket. Hey, it's the first distributor I've done since my VW back in the '70's, what can I say?
Anyhow, I use a socket on the alternator bolt to turn the engine to TDC in accordance with the mark on the distributor before removal. I carefully lifted it out of the socket so as to not disturb the oil pump drive and put it back in with the rotor splitting the difference between the TDC marker on the distributor and the screwhole for the cap. I was in shock when it dropped right in and was all lined up the first shot So shocked that I had to climb directly over top and look at it, then from all angles. Such a phenomenon needs to be admired.
Old Jul 17, 2020 | 03:04 AM
That's probably the easiest way. When pulling distributors I do mark them down at the block towards the distributor itself. And with a Sharpie the location of the finger towards the distributor case. I do a #1. When you pull it straight out the finger will move the amount that the helicoidal gear meshes impart on the inner shaft of the distributor. Just mark that as position #2 between finger and distributor case.
Even with a new distributor it can fall right in if you position all the parts the same way. Did it on mine too.
An added plus is that this would actually work in any position even when the engine is not on TDC.
Nice you have been that lucky.
Couple of days ago I just made a nice long 10 mm (3/8") rod and milled a screwdriver blade onto it to fit the oilpump of a 1963 Studebaker V8 for priming. Should fit the Blazer as well.
medicineman2011
Dec 26, 2017 01:56 PM
Autotech13
Aug 28, 2013 09:22 AM
1sexyblzr
Jun 15, 2010 01:54 PM
freonchill
Apr 14, 2009 10:45 AM
mdemers2006
Aug 10, 2007 11:39 PM
