oil leak from back of engine alternator side
Old Oct 19, 2019 | 11:44 AM
Tyler House's Avatar
Tyler House is on a distinguished road
Default oil leak from back of engine alternator side
leaking oil out the back of my engine on the passanger side. im sure it is not the valve cover gasket as i just changed it.
i believe it is the oil sending unit as it only leaks when running and because of where the oil is dripping down from.
could anyone verify this for me please.
edit/ 2002 blazer 4.3L
Old Oct 19, 2019 | 01:01 PM
Could very well be the oil pressure sending unit. The most common source of oil leaks from up high on the 4.3 is from the lower intake manifold gasket.
Old Oct 19, 2019 | 01:29 PM
Well the sending unit had oil all around it and it seems to be where the drip originates from. I am going to grab one now with a oil sending unit socket as well.
Also I had to pull the distributor to get to the oil sending unit. When I did there was a circular gasket of some kind that just literally crumbled away from the top of the shaft of the distributor. Could someone tell me what that was?
clbychil
Mar 8, 2011 01:35 PM
Invertiguy
Oct 24, 2010 02:57 PM
1sexyblzr
Jun 15, 2010 01:54 PM
d02046612
Jan 27, 2010 04:26 PM
MagicMan
Apr 30, 2008 12:49 PM
