Oil Pan
Old May 7, 2007 | 04:35 PM
moonshiner500's Avatar
moonshiner500 is an unknown quantity at this point
Default Oil Pan
I busted my oil pan acouple of weeks ago four wheeling and i was wondering what would be the easiest way in changing it? Thanks
Old May 7, 2007 | 04:52 PM
Default RE: Oil Pan
What are we talkin' about here? Year would help greatly. I can assume a 4wd which means you pretty much have to either drop the front axle or jack the motor to get the pan off.
If it is a '96+ truck with the cast oil pan, then you will really have to pull the motor to replace it. The oil pan is a structural member of the engine/transmission. If the transmission is bolted up when you install the replacement pan, you will most likely have leaks due to misalignment.
Old May 11, 2007 | 05:58 PM
Default RE: Oil Pan
Yea its a 93
Bluebeastblazer57
Aug 11, 2012 11:05 PM
kakn
Jan 14, 2007 01:18 PM
LoLoS10Blazer87
May 28, 2006 09:11 PM
blazingsadle
Apr 10, 2006 05:50 PM
swartlkk
13
Dec 20, 2005 08:13 AM
