Oil Pan
Old Jul 14, 2009 | 09:16 PM
andrea's Avatar
andrea is on a distinguished road
Post Oil Pan
I was just in a car accident with my Chevy Blazer 4D. I have a push guard on the front of it, and the impact of my accident happened to push my whole engine back about a inch and a half, and the oil pan struck a bolt and now the oil pan has a hole the size of a bolt in it.
I was wondering if it was worth it to buy a new oil pan, and try and fix the problem. But then i thought, i don't know if there are any others problems with it, since everything was pushed back. Is there any way of telling there are other problems?? I have no engine lights on, and it drives find, but obviously i can't drive it with no oil. Any suggestions?
thankss.
UPDATE: july 15th.
Called a pro. && he said that i could apoxy the hole, and it probably will work. He has already done it to two cars before, and it worked perfectly fine. After i do the apoxy, i have to take it to get aligned to see if frame is bent, or any other problems. If the frame is fine, and the apoxy doesn't work, it'll be 1,000 to have a whole new oil pan. But the problem is if there is anything wrong with the frame or axle, or anything else. I'll be fixing most of it tonight, hopefully drivable by tomorrow night, and then out to get it checked out.
thankss.
Old Jul 14, 2009 | 10:33 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
Ouch sorry to hear that..Is the engine still pushed back? Check to make sure your Distributor didnt hit the firewall...And how did you test drive it with a hole in the pan? Did You plug it first?
Old Jul 14, 2009 | 11:38 PM
rriddle3's Avatar
If you actually did push the engine back 1.5 inches you have a lot more problems than just the hole in the oil pan. See a professional.
Old Jul 15, 2009 | 12:13 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
i agree, i have a feeling that the hole in the oil pan is going to be the least of your worries.
Old Jul 15, 2009 | 01:49 AM
1995 Blazer's Avatar
1995 Blazer is on a distinguished road
yea my friend hit a phone pole and did the same thing pushed the engine back and that car went to the junkie
Old Jul 15, 2009 | 09:51 AM
andrea's Avatar
Default oil pan
The engine when it pushed back and hit the oil pan, it hit the bolt and the pushed back out...Its not like the oil pan is stuck with the bolt inside of it...it seems the engine pushed back out on impact. But most of you say its the least of my problems, which really suck, cause i can even afford a new or used car..
Its actually going into the shop today, but who knows how long it will sit at a shop and wait for it to be looked at.
Bluebeastblazer57
Aug 11, 2012 11:05 PM
kakn
Jan 14, 2007 01:18 PM
LoLoS10Blazer87
May 28, 2006 09:11 PM
blazingsadle
Apr 10, 2006 05:50 PM
swartlkk
13
Dec 20, 2005 08:13 AM
