Oil pan gasket replacement 97' Blazer
Old Dec 22, 2010 | 10:38 PM
Akira2008's Avatar
Akira2008 is an unknown quantity at this point
Default Oil pan gasket replacement 97' Blazer
Hello everyone. I'm new to the forum and could use some directions around here. Don't know if i'm in the right spot. I'm needing some information on the easiest/ best way to replace oil pan gasket on my 1997 S10 Blazer. Any help would be greatly appriciated.
Old Dec 23, 2010 | 07:22 PM
Blazer Steve's Avatar
Blazer Steve is on a distinguished road
Two options lift the motor, don't know if you can raise it enough to drop pan.
I pulled motor. I rebuilt engine and trans.
Or drop the front axle diff. I'm going to be doing that this spring
Going to replace all the seals and gaskets.
marcspector
16
Oct 23, 2015 09:26 AM
jtch75
Mar 30, 2015 10:32 AM
thundergod66
Nov 20, 2012 06:02 PM
AaronGene02
Jan 24, 2010 11:38 AM
kakn
Jan 14, 2007 01:18 PM
