Oil Pan Question
Old Mar 3, 2010 | 09:10 PM
bondable's Avatar
bondable is on a distinguished road
Default Oil Pan Question
Can't believe I was this stupid.
I have a 1998 GMC Jimmy with a 4.3L that died. I removed all the parts I thought I would need for spares and what not and threw out the block.
I picked up another engine that came from a pickup which was the same year, and went to put it in the Jimmy, this is where I realized my mistake...Oil Pan was different...shoot... I will end up getting another oil pan from the wreckers but my question is this.
Will I also need to change oil pump pickup tube also? or will I get away with just replacing the Pan?
Old Mar 3, 2010 | 10:54 PM
1997 red blazer's Avatar
1997 red blazer is on a distinguished road
4wd pans are deeper, if the engine you got was a 2wd the pan is not as deep, so you need a different pick-up tube for the deeper pan. Not sure witch way you went as you did not tell us if it is 4wd or 2wd ? But yes the tubes are different. Hope this helps
Old Mar 4, 2010 | 09:15 AM
bondable's Avatar
yes it is 4wheel drive
Bluebeastblazer57
Aug 11, 2012 11:05 PM
lowloudnproud1
Sep 2, 2010 06:41 PM
biniecki
Nov 6, 2009 03:05 PM
Duckboat
May 29, 2009 10:17 AM
swartlkk
13
Dec 20, 2005 08:13 AM
