Oil Pressure Question
Old Feb 3, 2012 | 10:26 AM
Little Roober's Avatar
Little Roober is on a distinguished road
Default Oil Pressure Question
When the oil is cold should the pressure be higher or lower than when it's hot? Also, what is the standard for our trucks? 40?
Old Feb 3, 2012 | 10:42 AM
rriddle3's Avatar
Usually slightly higher when cold. Most will show 40-60psi when cruising.
Old Feb 3, 2012 | 10:48 AM
pettyfog's Avatar
higher. Oil pump bypass is about 57 lbs. Gauge will read a little higher when cold.
As oil warms, pressure at given rpm will drop. Meaning higher rpm until oil pump bypass.
Old Feb 3, 2012 | 10:54 AM
chris015's Avatar
My s10 shows at cold start on a cold morning around 70 psi. and around 45-50 at warm idle for at least 30 min worth of driving. then it'll gradually drop down to 30ish idle and 45 at 2000 rpm..
Healthy
Old Feb 3, 2012 | 11:57 AM
The reason I ask is my Jimmy has been around 50 lately, but with the warmer weather it's been closer to 40. Just makin sure it's not gunna blow up. I'm about to check and make sure the oil level is still normal though. I'm sure that'd make it drop too.
Old Mar 20, 2012 | 04:01 PM
hshark's Avatar
hshark is on a distinguished road
Along with checking oil level it doesnt hurt to change out the oil pressure switch. Sometime those things go bad, and give false readings.
LWegner
May 8, 2011 08:25 AM
Spectreblazer
Mar 15, 2010 11:16 PM
davidsv8mustang
Feb 18, 2010 02:29 PM
zippy199
Oct 22, 2009 06:36 PM
Ak95Blazer
Jan 7, 2009 06:56 AM
