Oil Pressure Switch
Old Dec 1, 2008 | 07:14 PM
wcolclou's Avatar
wcolclou is an unknown quantity at this point
Default Oil Pressure Switch
My brother has a 2005 Blazer. He wants to know if anyone knows how to change the oil pressure switch. He believes that the distributor must come off???
I have a Jimmy the same year but haven't had time to look.
Thanks,
Bill
Old Dec 1, 2008 | 08:51 PM
Hanr3's Avatar
Default RE: Oil Pressure Switch
Its a pain in the butt, however you can change it without removing the distributor. If you want to remove the fitting between the sensor and the block, then yes you need to remove the dist. It is also easier to remove the dist, although that depends on which way yours er rather his is pointing now.
sbrookover
Dec 25, 2009 02:42 PM
robkolo1
Nov 27, 2009 10:40 PM
mcvay20
Feb 17, 2009 01:52 PM
wcolclou
Nov 25, 2008 07:17 PM
guywm25
Apr 10, 2008 04:36 AM
