oil pump cover gskt
oil pump cover gskt
Im leaking oil from the where the oil pump cover meets the block. There are 2 bolts holding the cover to the block and 2 lines that go to the cooler. Is removing those 2 bolts going to be enough to lower the cover and change the gasket?
edit: is oil pump cover gasket the correct way to refer to it?
Um... Please clarify what you are talking about. The oil pump is internal to the pan. There is no oil pump cover. Are you talking about the remote oil filter adapter at the engine block?
Thats got to be what he is talking about he just didn't know proper verbage.
No its not the oil filter adapter. Left/driver side of the vehicle, beside the oil pan. The red words in the picture say "this thing" and an arrow pointing to the leak. Whats that correct way to refer to "this thing" and the gasket for it. Read first post after reviewing picture please.
thanks
EDIT: Someone told me its called a oil cooler line mounting block, found the gaskets also.
thanks
amart
12-24-2011 04:51 PM
