oil pump replacement
Old Nov 23, 2013 | 06:54 AM
blazer485's Avatar
blazer485 is on a distinguished road
Cool oil pump replacement
hi all you blazer guys and gals ,ive been around here a while and alot of you have gotton me out of some jams and for that i thank you.however i need to call on your advice once more, heres what i got= 2000,4wheel drive,4.3 liter aautomatic tranny,all stock truck,anyway ive had low oil pressure for about 40,000 miles.when i start the truck oil pressure is normal after warming up she drops to 10-15,i no specs say between 8 and 50lbs is suficient but it allways had between 30 and 60 before i had the intake gasket done.anyway can i fix this problem without removing the motor ? i no tall order right ? i would appreciate some help on this problem, thanx in advance,and happy holidays to you and yours everybody !!!!!!
Old Nov 23, 2013 | 09:57 AM
CAB's Avatar
CAB
CAB is on a distinguished road
Is that pressure reading off of the stock gauge? If it is I would use an exteranl oil pressure gauge before any work gets done to verify. After 40K miles, if it has a low oil pressure problem I would think the motor would be toast by now.
Old Nov 24, 2013 | 06:55 AM
blazer485's Avatar
Default oil pump replacement
yea i no but nope the engine runs like atopp,thats why im so confused,ive been around and worked on vehicles all my life. im stumped.
BouncingRadical
14
Nov 27, 2015 12:30 AM
lowgear
Jul 11, 2015 05:30 PM
Coinhunter
Oct 4, 2013 06:52 AM
Mr.T
Nov 2, 2010 06:26 PM
todaresqSL2
Nov 10, 2008 01:47 PM
