Overheating at idle
Old Sep 14, 2022 | 05:45 AM
Drizzt368's Avatar
Drizzt368 is on a distinguished road
Default Overheating at idle
I have a 2004 Chevy S10 Blazer 4x4 and it started to overheat yesterday as I was stuck in stopped traffic. once I started moving again the temperature went back to normal, it drove fine all the way home but once I stopped in my driveway and let it idle for just a couple of minutes i the temperature started climbing quickly again. What could be the issue?
Thanks
Old Sep 14, 2022 | 08:03 AM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
Cooling fan. At idle it should be running. I am not familiar with what we have for fan clutches but that is where I would look.
Old Sep 14, 2022 | 03:39 PM
I'm assuming you have a fan shoud installed? I discovered how important a fan shroud can be with my 68 Mustang. Without it, overheating while idling on any summer day. With it, no more.
Old Sep 15, 2022 | 04:18 PM
Stovey's Avatar
Stovey will become famous soon enough
Perhaps this is too obvious but the coolant level should be checked.
Old Oct 12, 2022 | 06:01 PM
joseywales's Avatar
joseywales is on a distinguished road
Default Usually this .....
Thanks
first replace the thermostat and get a " fail-safe" if you can , then warm it up and see if that helps , if not squeeze the upper rad hose and you should feel the pressure , if not and it squeezes easily ,make sure the engine is fully warm , but then your looking the water pump , cheapest and easiest stuff first though .,
phatmatt54
Sep 14, 2014 02:37 PM
4uzindian
Dec 30, 2011 04:25 PM
footbrake
Dec 17, 2010 07:18 AM
00bluegtp
May 27, 2010 09:37 PM
deadeyeden
Feb 16, 2009 08:20 PM
