Overheating too often.
RE: Overheating too often.
That is true about waterpumps being centrifugal but what I believe he ment is that there could be a brokenfin inside the water pump. My buddy's fullsize chevy had broken fins inside his water pump that luckily stayed right there without circulation. I don't know how else to describe it besides a fin or blade.
Most impellers in modern water pumps are stamped steel. They are spot welded together. Most common failure is the bearings, but if the welds are poor, the impeller can break loose of the drive hub.
fmalloch
04-21-2013 06:59 PM
mudd_toyz75
09-18-2009 08:39 PM
paulbaby
08-19-2008 08:28 PM
