P0171 & p0174
Old Jun 27, 2018 | 05:59 PM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Default P0171 & p0174
Been having issues for a while now without any codes. Symptoms include misfire under load and thats about it. Occasionally the SES light would flash while misfiring going up a hill on the freeway. Hills in general is the only time I would have the misfire, or getting on the freeway.
Anyway, did a light tow of a small trailer and it got really bad. SES flashed but when it was done it did not stay on. For sharts and giggles I decided to do a scan and codes P0171 and P0174 popped up, remember the SES Light DOES NOT stay on while running. Like I said I've been having this problem for the past year and a half with no avail in fixing it. Since it started I have done:
Plugs, wires, cap, rotor, air filter, fuel injector, fuel filter, fuel pump, intake gaskets. I've also swapped multiple sensors from another blazer to test if I had bad ones (I didn't).
I've looked up some probable causes and solutions to these codes, most I have done (replace parts, sensors). I tried testing for a vacuum leak but couldn't find anything. I also replaced O2 sensors 2 years ago (before the problem arose).
Hoping someone can maybe give me a few more ideas more direct to what I have going on, thanks.
Old Jun 28, 2018 | 02:39 AM
Can you please give us also the year, engine, transmission of the blazer. From the codes it is an OBDII but then all are after 1995.
Old Jun 28, 2018 | 08:21 AM
LesMyer's Avatar
Scan for pending codes in same key cycle as the misfire. Bet you will have a pending misfire code. That might help give additional info. Also check cam sensor retard with a capable scanner and make sure is zero ±2° - this being off can cause those pesky misfires..
Old Jun 28, 2018 | 03:18 PM
Its an 04. 4.3 with 4l60e
Old Jun 29, 2018 | 03:38 PM
rriddle3's Avatar
Have you read these two threads:
P0171 Explained
P0174 Explained
bil2000
16
Sep 15, 2020 09:06 PM
Jimmy_Blazer
Oct 27, 2016 09:07 AM
Tsigreg
Oct 15, 2012 09:23 PM
LittleT
Oct 23, 2007 01:02 PM
Tuff4stroke
May 14, 2007 11:55 PM
