o2 sensor
Old May 14, 2007 | 10:20 AM
Tuff4stroke's Avatar
Tuff4stroke is an unknown quantity at this point
Default o2 sensor
Hi I have a 2001 that i had a ses light on knew i needed to change plugs so ,when at Autozone had them stick code reader on it.
two codes: 1 for plugs and 1 said the oxygen sensor on the drivers side needed replacing( i think about $56.00) codes were pu300, pu174
can someone let me know where is it and is it a difficult fix
thanks!
Old May 14, 2007 | 10:26 AM
Default RE: o2 sensor
typo i believe codes p0300, p0174
Old May 14, 2007 | 10:30 AM
Yeah, I know what you mean.
P0300 Random Multiple Misfires
P0174 Fuel Trim System Lean Bank 2
I'd do a tune up (plugs, wires, cap & rotor) and clear the codes. Then see what pops back up.
Old May 14, 2007 | 09:07 PM
thanks for your time how do i clear the codes ...
Old May 14, 2007 | 09:25 PM
You can unhook the battery negative for a good 10-15 minutes and it should clear the present codes in the PCM.
Old May 14, 2007 | 11:55 PM
20Blazer00's Avatar
That is the easy way if you don't have a code scanner.. Do it while you replacing plugs, wires and cap/rotor..by the time you get those items installed your computer should have dumped the memory and codes...
joey
Aug 27, 2012 06:33 PM
GM hater
Jan 9, 2010 02:32 PM
theeviltwinn
Oct 23, 2009 06:37 AM
daniel010
Feb 2, 2009 06:50 AM
Spartan66
Jul 11, 2008 02:34 PM
