P1345 Code: motor stutters after after 40 mph
Hey y'all, I just got my blazer up and running again. Had to replace my HVAC hose. Now when I hit 30 mph it revs up like it do t want to shift. But if I take my foot off the gas pedal and reapply it shifts fine. Once it reaches 40-45 mph it begins to stutter. I ran a code reader and it comes up with the following code. I can't find anything about it in my Haynes book, any help would be appreciated.
Loose or missing hold-down bolt for the distributor; broken wires or rubbed through insulation...take a look at the plug at the base of the distributor. It is very close to the firewall, so the wires could be damaged. Excessive play i the timing chain could also cause the issue.
In your shoes I would try to locate and fix the problem myself...but then you have to have the camshaft retard set and a crankshaft relearn done. These can only be done with a capable scan tool. The ones you get at the auto parts store can't do it. Unless you got a buddy with the right scan tool and the knowledge to use it correctly, your going to have to go to a shop or the dealer to have it done.
Alright. I appreciate the help gentlemen. I got the timing issue taken care of, not I'm back to the issue of my rig not shifting again. I drive down the road and when it hits 35 mph it just revs up. It won't shift.... Any advice on how to correct it or what to look at?
joethejman4us
Feb 16, 2010 09:25 AM
SuperBlazer
Feb 6, 2009 03:33 PM
4x4willywill
Dec 23, 2007 04:33 PM
Mr Blazer LT
Jan 17, 2007 11:25 PM
