part # 15154323
is there any one who knows for sure if the part # 15748800 will replace part number 15154323
these are the tccm for my 99 blazer
so far the info i have found online says yes but most of this is from the companies selling the product
thanks
graham
welp
ellis
thanks
graham
welp
ellis
Yes the 15748800 ill replace the 15154323. I just replaced one in a 1999 Blazer with the NP8 2 speed transfer case with the 4 button switch. Works like a charm. Make sure you clean all the contacts before installing. Actually you want the 12577412 because it replaces the 15748800. All the bugs are out of the 12577412.
Hope this helps.
Hope this helps.
yes thanks for the reply I had already taken my chance and purchased the part from a parts store out of Houston about 4-5 hundred less than ordering it from my local dealer and even 2-250 less than local auto wreckers.
plugged right in no problems fixed all the issues
thanks
thanks
spider21
Nov 17, 2011 06:27 PM
