Passenger side oil leak unknown source
Old Oct 24, 2012 | 10:02 AM
trk14's Avatar
trk14 is on a distinguished road
Default Passenger side oil leak unknown source
Hi guys, I hope you can help with this.
So I've been working on and off on a 96 blazer 4wd with 203k miles for almosta year trying to get it on the road. I now have an oil leak coming from the front passenger side. The oil pan, part of the passenger side control arm, and front skid plate all have a thin layer of oil on them. the leak itself seems fairly slow; my oil dipstick has only registered a slight drop. When I park after driving for a while, there only seems to be a few drips on the ground.
Any ideas on where to look? My automotive knowledge is just enough to get me in trouble.
Old Oct 24, 2012 | 10:13 AM
richphotos's Avatar
Could be the oil lines from the remote oil filter to the engine block, pretty common problem with these things.
Old Oct 24, 2012 | 10:19 AM
rexmburns's Avatar
Super Moderator
^x2^ also check around your valve covers as they leak frequently and check the torque on the oil pan bolts. I've read several old threads in the last couple days about the bolts working loose and causing a small leak while reseaching what else I should change when I have my trans out.
Old Oct 25, 2012 | 09:37 AM
trk14's Avatar
Thanks guys. I'll try and give you an update tonight.
tate456
Aug 7, 2013 07:10 PM
upmaine
Jul 9, 2012 12:31 PM
cory.kiel
Apr 20, 2011 06:52 AM
Sturg
Oct 27, 2010 09:57 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
