PCV Valve noise - vacuum hose issue
Old Jul 7, 2013 | 06:02 PM
chevyman93's Avatar
chevyman93 is on a distinguished road
Default PCV Valve noise - vacuum hose issue
So i replaced my pcv valve& hose thinking this would fix the rattle noise issue, but i believe it is being caused because of an vacuum hose in this diagram is not hooked up, also it seems to only be affected until the engine gets to 210 running temp, and might be the reason my tac jumps a bit while cruising, and it chugs under light acceleration. The engine light came on today because of this. In the diagram all in blue and everything else is hooked up but the red i can not figure out where it goes to this might be my issue. PCV Valve noise - vacuum hose issue-actuator-controls-front-axle-ts0650201.png
Old Jul 9, 2013 | 12:59 PM
abig84's Avatar
That looks like the vent tube and its not supposed to be hooked up to anything. If you follow it back into the blue lines it goes the vacuum switch vent, the vent on trans and transfercase. If there's vacuum pulling out of that hose the switch might be plumbed wrong. If not leave it alone its fine
Old Jul 10, 2013 | 04:58 PM
chevyman93's Avatar
Awesome thanks abig84, ill double check my work and see if they all are connected to the switch the right way, i replaced all my lines but the smog pump one, and just the other day i replaced that one and i think that did made the noise go away or at least some, was a small leak in that hose.
Old Jul 10, 2013 | 06:51 PM
chris015's Avatar
wait is the rattle coming from the pcv? if so thats normal. the chugging issue could be another problem.
Old Jul 10, 2013 | 07:37 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
+1 to Chris015
Old Jul 11, 2013 | 08:50 AM
chevyman93's Avatar
Well the pvc value does make some noise i know but i was hearing it pretty loud in the cab but now i dont really hear it in the cab anymore, also i figured out the chugging issue was due to a bad colant temperature control value. So it was chugging, making the tac jump when it did, and causing the engine to have a hard time cranking over unless the engine was just recently run and is still warm.
Tonyrodz
Jan 26, 2012 04:57 PM
89Recon
Oct 22, 2011 05:50 PM
96jimmy4.3
Nov 14, 2010 02:55 PM
Resolute
Dec 25, 2007 03:58 PM
blazinloud
Engine & Internal
Sep 14, 2006 12:08 AM
