please help
Old Feb 15, 2011 | 05:27 AM
lilebes's Avatar
lilebes is on a distinguished road
Default please help
thanks in advance for any help. here is my problem. I have a 98 blazer with the 4.3 4x4 and i started getting a P0118 code which is for the coolant temp sensor high input. i replaced my coolant temp sensor between the #3 and 5 plug with a brand new one and now my truck runs worse than before. The check engine light comes on and my temp gauge bounces all around or just sits at 100. the truck sputters and stalls at times. can anyone help me out with what may be causing this problem/
Old Feb 15, 2011 | 07:19 AM
Sounds like you might be experiencing a wiring issue. Try testing all of the wiring noted in the link below. If that doesn't work, go through the diagnostic steps.
P0118 - Engine Coolant Temperature [ECT] Sensor Circuit High Voltage
Old Feb 15, 2011 | 11:07 AM
lilebes's Avatar
would my battery not being very good cause any of this. My battery is very weak and i was just wondering if that could cause this issue as well
opposedforces
Sep 1, 2011 02:59 PM
BlazerPunisher
Mar 23, 2009 05:47 PM
rogggg1020
Nov 11, 2008 08:05 AM
blazin4eva
Feb 26, 2005 12:04 PM
blazin4eva
Jan 27, 2005 02:02 PM
