Please help me out with this annoying problem
Old Feb 26, 2019 | 07:39 PM
Madson26's Avatar
Madson26 is on a distinguished road
Just wanted to update... All that mess was a $70 fan clutch and about an hour and a half... Roars extra loud at start-up now, but quiet while running speed downhill. I do believe she's good to go
Old Feb 26, 2019 | 08:02 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Good work!
Old Feb 26, 2019 | 08:18 PM
cleburne red's Avatar
Nice! Glad to hear you got it fixed.
Old Mar 31, 2019 | 09:58 PM
Madson26's Avatar
I spoke too soon... It still does it. I found out heading out of town for the weekend. 🤬
But I was surfing another forum and FINALLY found someone else that has had the same problem. It turns out that it's one of the forks inside the transfer case, but I don't know which one (load fork maybe?). Either way it looks like a rebuild is coming soon.
This will make the 5th transfer case in my S-series ownership since 03. I should have bought an Atlas or a Stak for my SFA 95, but this will be my first issue with the NP233
Old Apr 1, 2019 | 05:17 AM
The tcase fork is causing the problem? How does that work?
Old Apr 1, 2019 | 11:22 AM
Madson26's Avatar
Originally Posted by cleburne red
The tcase fork is
This is the explanation I got from another forum...
it has nothing to do with the tq converter, transmission or tune. It’s the transfer case. This was 3 trucks ago for me so my memory is a little fuzzy but I believe it was a worn fork that allows it to be between gears when being driven backwards(wheels driving the rotation of the drivetrain-not the engine(not physicaly driving backwards)). But then it realigns when imput torque comes from the engine again. Get a new transfer case, rebuild yours, either way you will solve the problem. I had a pump rub kit in mine, still did it, 2 different issues.
Old Apr 1, 2019 | 11:47 AM
Hmm. Seems weird but who knows. The Np233 is really easy to rebuild, I just went through mine a month or so ago. Rock auto has good prices on rebuild kits.
There's about a million c clips you'll have to remove, which is awful. You can do it with snap ring pliers, that's what I did. I ground off the points to be able to use the wider part. If you can come across some c clip pliers, that would make the job much easier. Think snap ring pliers, but the ends are wider.
Old May 16, 2019 | 06:57 PM
Madson26's Avatar
The fella on the other forum was 100% correct! I just got it out of the shop today with the case rebuilt. I feel like I got a good deal having it cost $605 all in. 335 to r&r and 270 for the rebuild. Everything inside is new and the cases hot tanked. The shift fork was completely wasted and the planetary wasn't far behind. He showed me the old parts compared to new ones. The BlaZR2 is back on the road and not afraid to take her anywhere! Thanks again for the help
Old May 16, 2019 | 09:13 PM
$605 to rebuild a tcase! Sheesh, I need to start a side business. I would only charge 500 lol.
Glad you got it figured out, man!
Old May 16, 2019 | 09:44 PM
Madson26's Avatar
Thanks. I just closed on my house last week and I'm moving. I have everything packed up and nowhere to work. I paid 270 for the full rebuild. A shop across the lot from the garage that rebuilt it charged me more to pull it and reinstall and fluid. 335. Normally I would have pulled it myself but I was in a spot
