Please help! Rough 1-2 Shifting
Old Nov 29, 2012 | 06:08 PM
bostonblazer22's Avatar
bostonblazer22 is on a distinguished road
Default Please help! Rough 1-2 Shifting
Hey
Have a little issue here. I just had my PCM replaced in my 98. It was running perfect fine around town and at under 50. I noticed the other day that when I was hitting 60mph, I came to a stop and I had a really rough 1-2 shift. Once I shut the car off and let it sit for a minute, it was fine.
Today I went on the freeway and hit 65+ for about 5-10 and my check engine light came on. I haven't been able to read the code, but I noticed I was having hard shifting 1-2.
Could this be another bad PCM?
Has anyone else had these issues? I'm tired of fixing it but it's my only car.
Thank you!
Old Nov 29, 2012 | 07:54 PM
Really need to find out what codes are in memory.
Have them retrieved and post them in the order they are retrieved.
Could be a sticky shift solenoid or spool valve in the valve body.
If trans fluid temperature is too hot it can cause a high, harsh 1-2 shift.
Did you have the new PCM flashed to your VIN?
Did you perform the crankshaft position sensor relearn with the new PCM installed?
Old Nov 30, 2012 | 10:35 PM
cucv30's Avatar
cucv30 is on a distinguished road
you'll probably find an 1870 code. That happens when the tcc regulator valve bore gets worn and leaks oil past when hot.
lawclagett
May 12, 2012 12:46 PM
fiXXitup
Sep 2, 2009 12:47 AM
Blazin1
Oct 21, 2008 07:54 AM
4byluv
Nov 16, 2007 12:01 AM
96jimmy4x4in
Oct 7, 2007 09:23 PM
