Pop, grind, no go
Old Jul 10, 2018 | 12:09 PM
Jerzey1044's Avatar
Jerzey1044 is on a distinguished road
Default New member Pop, grind, no go
I have a 2000 blazer LS .I was driving home a few days ago and out of nowhere I heard a pop(unclear on the pop though cause the grinding scared me tbh)then a hard grinding sound so I brakes and pulled to the side. The speedometer needle barried to the top. (100mph). I turned the truck of got out and started to investigate initially everything seemed in order no smoke no smell popped the hood checked fluids tranny fluid was brown but no leaking from anywhere til I looked in the back end and the differential seemed to be leaking. I got back in started right up but it wouldn't engage any gear I tried R gassed it nothing but rpm raised then ttied each gear after D 2 1 all the same result. No movement. At a loss for words I have a few ideas of what it might be and I'm hoping its not what I think it is. Any information would be helpful. Thanks in advance. Rear end only pic for now
Last edited by Jerzey1044; Jul 10, 2018 at 02:09 PM. Reason: Forgot to add new member
Old Jul 10, 2018 | 02:24 PM
LesMyer's Avatar
Sounds like the transfer case let go, but you haven't said if it was a 4WD or not. I assume the driveshaft isn't turning.
Old Jul 10, 2018 | 02:31 PM
Jerzey1044's Avatar
Its 4wd
​​​​​​Thanks for your in put
Old Jul 12, 2018 | 02:38 AM
Jerzey1044's Avatar
Default No
No I don't think it was I just kno it made a horrible gear grinding sound and then would not shift in to gear shifter moved as it normally would but when I gave it gas the rpm went up and the speedometer stayed buried at 100 on every single gear. Need to know if there is a solution to be able to limp it home 5 miles
Old Jul 12, 2018 | 07:50 AM
LesMyer's Avatar
Well, if it doesn't move under its own power you will need to have it towed................ Really don't have sufficient info to tell you anything else.
Tenagator
Dec 24, 2013 10:59 AM
Txguy
Sep 6, 2010 04:52 PM
RnB1987
Aug 17, 2010 03:26 PM
pirkeltooned
Jun 10, 2010 11:11 PM
14Blazer88
Feb 12, 2009 01:13 PM
