Possbily need an ECM now?
Old Oct 10, 2011 | 11:20 AM
cochran07's Avatar
cochran07 is an unknown quantity at this point
Default Possbily need an ECM now?
Well any of you that know me know I just rebuilt the engine in my Jimmy. Well it was running great for like a week and a half and now all of a sudden its acting up. Idles fine and smooth, so I know the engine build is fine. You try to open up the throttle any it trys to cut out. Also I lost all my guages. None of them work at all. I found an old aftermarket alarm system on it and it was spliced in to my ignition harness which I figured. So I replaced that and nothing still. Any ideas? Ive pretty much narrowed it down to a wiring problem somewhere or the ECM is somehow in limp mode or fried all together. I dunno any ideas welcome.
Old Oct 12, 2011 | 03:00 PM
cochran07's Avatar
Well I found the problem of engine running bad. Its fixed but still my gauge cluster is not working. Going to tear it all apart (obviously already checked my fuses) and see if Im getting power back there tonight. Any other ideas throw em out there.
Old Oct 12, 2011 | 04:23 PM
Magmotor's Avatar
Magmotor is on a distinguished road
Would be interested to know what fixed the "running bad" problem.....i'm guessing on this, but if you have a digital cluster, I hear there is a small power board, inside the cluster, that usually goes bad....you might give that a try.....
Old Oct 16, 2011 | 08:50 PM
cochran07's Avatar
No it was a wire that grounded out the whole truck. Ive never seen anything like that before but fixed the wire and it started running perfectly fine and hadnt had any issues since. No my gauges are not digital but thats fixed as well.
Old Oct 18, 2011 | 07:07 AM
TZFBird's Avatar
TZFBird is on a distinguished road
Sounds like you got off the jump-to-conclusions mat and actually did some investigating. Glad you got it taken care of.
Old Mar 7, 2012 | 03:13 PM
moe_23's Avatar
moe_23 is an unknown quantity at this point
What wire ended up causing the problem? I'm currently experiencing ecm problems myself and have no idea what is causing the problem.
Old Mar 11, 2012 | 09:16 PM
cochran07's Avatar
It was something that I wired incorrectly cause I got in a hurry, so basiclly I had a wire running thru my door jam that got pinched and was grounding out the body.. Took the wire out ran it correctly through the firewall and a grommet and everything is fine. just goes to show dont rush wiring and do it incorrectly (which I already knew)
larrya97
Jun 20, 2013 12:17 AM
Dadatone
Aug 17, 2012 09:48 AM
roddy
Jun 28, 2012 04:52 PM
NC93BLAZERLT
16
Jan 4, 2010 11:08 AM
pandabaer
Oct 25, 2005 01:22 AM
