possible 4l60E to 700r4??
Old Nov 9, 2008 | 12:28 PM
fourplayinmi's Avatar
fourplayinmi is an unknown quantity at this point
Default possible 4l60E to 700r4??
I have a 92 s-10 blazer 4x4 4.3l not sure on the tranny but I have a donor blazer (93) same motor but has the push button 4wd and not sure on what tranny is in it but if it is a 4l60e how would I go about to get it to work in the other (92) blazer
is it possible to do? please help!!!
thanks
Old Nov 9, 2008 | 01:18 PM
WolfPack's Avatar
Default RE: possible 4l60E to 700r4??
https://blazerforum.com/m_183840/tm.htm
Old Nov 9, 2008 | 01:39 PM
doesnt answer my question though
Old Nov 9, 2008 | 01:48 PM
WolfPack's Avatar
So you wanna put the 93 tranny into the 92 blaze.
I think they added the 'e' somewhere around there...4l60 (which is the same as the 700r4?) up till 92 or 92, then it was the 4l60E.
Wheres Hanr3
Old Nov 9, 2008 | 02:40 PM
yes
Old Nov 9, 2008 | 05:13 PM
You would need to get a stand alone controller ($$$). Find yourself a non-"e" transmission to use.
Old Nov 9, 2008 | 07:35 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Yes, the '92 is a 4L60 while the '93 is a 4L60E - '93 was the transition year.
Like Swart said, you want a non-'e' tranny.
Old Nov 9, 2008 | 08:31 PM
okay thanks guys I had a buddie tryin to tell me that I can but I didnt think I could just swap it thanks alot!!
so I just need to look for an 700r4 or a 4l60 correct?
Old Nov 9, 2008 | 08:59 PM
4L60 == 700R4. There were modifications towards the end to increase reliability, but they are essentially the same.
You can use the 4L60E, however, the controller for it is $600-$800 depending on which one you decide to go with. I was looking at putting a 4L60E into my Chevelle and decided fairly quickly that I would be using a 700R4 if I wanted an overdrive automatic.
Old Nov 10, 2008 | 05:23 PM
Hanr3's Avatar
Fishing.
You all had it under control.
