possible starter short????
Old Nov 23, 2008 | 10:26 AM
rogggg1020's Avatar
rogggg1020 is an unknown quantity at this point
Default possible starter short????
has anybody heard of a short in the starter???well i can start the blazer and it runs fine nothing gets hot but if i have some trouble starting it the my battery post gets really hot after 10 to 15 secs cranking,,,,any ideas?????????
Old Nov 23, 2008 | 02:27 PM
Default RE: possible starter short????
If the battery post gets hot, I would suspect corrosion at the post causing resistance.
How long are you cranking on it when you "have some trouble starting it"?
How old is the battery?
Old Nov 23, 2008 | 02:47 PM
vin791's Avatar
vin791 is an unknown quantity at this point
it might be loose too and arcing which could be really bad and end up killing a cell in your battery.
Old Nov 23, 2008 | 03:25 PM
rogggg1020's Avatar
im only cranking on it for about 6 to 10 secs at a time but a couple of times each and its a battery less than 1 1/2 months old and post are tight,so i called my cousin in ky which ends up he works on police cars and he said my sileniod is drawing current in my starter even with the ign switch off cause sometimes cranking it would turn over a half turn and stop then i would turn the key off and retry it and starts cranking again,if all that helps,sometimes my cousin is full of crap too,lol,,any thing liks this sounds right?????
Old Nov 23, 2008 | 03:39 PM
If the solenoid were drawing current even when the key was off, it would drain the battery dead. Should be fairly easy to determine if that was the case.
Old Nov 23, 2008 | 04:03 PM
rogggg1020's Avatar
well if i leave the battery hooked up for more than 12 hours then it is dead
Old Nov 23, 2008 | 04:46 PM
Well then... More information. If you disconnect the starter, does the battery die?
Old Nov 23, 2008 | 05:59 PM
rogggg1020's Avatar
sorry i havent gotten that far yet lol,,,it got very cold outside and dark...lol
jdmmario
Oct 25, 2014 06:25 PM
mthomasc
Sep 23, 2010 02:56 PM
Katmandu
Jan 15, 2010 06:55 PM
grendragginbu
Oct 11, 2007 04:32 PM
jbeanz
Aug 6, 2007 08:12 PM
