Press gas paddle stalls pull throttle body revs
Old Jan 24, 2023 | 06:27 PM
That blazer guy's Avatar
That blazer guy is on a distinguished road
Default Press gas paddle stalls pull throttle body revs
Hello everyone I have a 2000 4wd zr2 two door 4.3 v6 automatic blazer I did a headgasket replacement and all other gaskets that are in the way of the head gasket. Put it all back together also put in a new steering pump and a cold air intake. We started it and it was kinda rough in the beginning cause of the break cleaner and the oil flush but we got a cam shaft position sensor code which wasn't there before. And now when we press the gas it dies but we can use the throttle body and rev it to limiter just fine. But it starts up and idles perfectly the only thing is, is it is kinds bouncy on the rpms but i figure because, we did rule that the maf is bad so I'm sure that's part of it. But we don't have any vacuum leaks, everything is plugged in, all plugs are good, no pinched wires, and everything on the pedal assembly seems good. Any other ideas on what it could be? All help is greatly appreciated!
Old Jan 24, 2023 | 07:51 PM
rockp2's Avatar
Double check your spark plug wires routing first. You wouldn't be the first by far to cross #1 & #3.
Do you have a scanner you can see the data PIDs with?
Old Jan 24, 2023 | 08:12 PM
rockp2's Avatar
I didn't ask, but was the code P1345? If so, I would first look at the distributor being off a tooth.
EDIT: If P1345, read post #2 in this thread: https://blazerforum.com/forum/2nd-ge...uestion-83333/
Old Jan 24, 2023 | 08:28 PM
Default Have not
I didn't think of spark plug wires I will check that, and i do not just a cheapy basic code reader. That code does sound familiar I'll see if that code pops up. Thank you
Old Jan 24, 2023 | 08:47 PM
rockp2's Avatar
All the other wires match the engine block on the distro cap except #1 & #3 are flipped. Pretty common error.
Trying
Jun 10, 2013 04:47 PM
~Smallz~
Oct 20, 2009 07:37 AM
xCHIPx
Oct 17, 2009 10:11 PM
crushr98
Apr 25, 2008 10:25 PM
Abby
Feb 7, 2008 10:20 PM
