problems with 95 Blazer - No start
Old Sep 14, 2009 | 09:07 AM
Lower_Level's Avatar
Lower_Level is an unknown quantity at this point
Sorry to pester, but this truck is just got the better of me and I'm totally at a loss.
We spent all weekend under this truck, tracing back for possible blockage in the fuel line, only to find that it was indeed the fuel pump that was the problem. We were able to pick up another one & once installed the pressure at the schrader valve was steady at 56 psi. Until the fuel line under the truck burst!!! I must have stressed it a bit when I was taking off the fuel filter. So we ran new line & now no leaks, adn still have a solid 56-60 psi of fuel pressure. But still the truck won't start. We have rechecked for spark; both at the coil and at the #1 cylinder. Everything is good. The only thing that we have found now is that after numerous tries to get the truck to fire, we pulled out a few plugs to find them bone dry! I'm wondering if maybe the injectors still aren't opening. But I went through the repair manual (broke down & got one) and I can't find anything on checking if the CPI is working properly. Is there any way to manually activate the injector to see if it is really opening & getting any fuel into the cylinders?
Old Sep 14, 2009 | 11:56 PM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
pull the upper plumun off and pull a poppet out and put it in a large clear empty bottle and disconect the iginition coil and then have a buddy turn the iginition key and watch the spray pattern coming out. it should be a nice symetrical cone shape.....if not, then its clogged....
Old Sep 15, 2009 | 07:44 PM
dylan71's Avatar
dylan71 is on a distinguished road
i am having the xact same problem with mine. i took the whole intake apart put it all together and now i cant get it to start. i have no clue
Old Oct 19, 2009 | 06:05 PM
old skool luvr's Avatar
Originally Posted by Lower_Level
Here's the part I'm talking about:
Originally Posted by bigdaddykane93
thats the manifold tuning valve. it has a flap under it that turn when necessary. but i dont know why its there, or what it really does. i took mone off today to look down the intake penuluim and i found a little fliud that smelled like gas at the bottom of the intake on both sides... why is it there? is this fluid supposed to be there?
this changes the air flow inside the plenum @ WOT. it's what gives the early vortec's (CPI) their extra power over the Z codes.
rickrob16
Jul 10, 2010 05:16 PM
multiplicityz
May 23, 2010 02:14 AM
7mmremag
Jul 3, 2009 10:40 PM
upblazer95
Apr 4, 2009 08:27 PM
crey 95 Blazre
Jan 5, 2008 03:55 PM
