problems with transmission on chevrolet blazer 1994 5.7 v8
Old Mar 12, 2010 | 03:33 AM
ivanex v8's Avatar
ivanex v8 is on a distinguished road
Question problems with transmission on chevrolet blazer 1994 5.7 v8
hi please can anyone help me what oil type come in to transmission on chevrolet blazer 1994 5.7 v8 also I need how oil filter for trans looks like.
Best regards,
Ivan Zambelic
Old Mar 12, 2010 | 06:15 AM
Auto = Dexron III or newer equivalent
Manual = depends... There were two transmissions offered from my references show. The NVG3500 (5LM60) uses Synchro-Mesh Trans Fluid T2850 while the NVG4500 uses Castrol Syntrog GL-4.
Old Mar 13, 2010 | 04:26 AM
ivanex v8's Avatar
thanks for fast replay,
the transmission isautomatic , alsowhat is thequantityinside pls.
bestregards,
ivan
Old Mar 13, 2010 | 08:32 AM
~6qtrs with a pan drop. A little under 12qts if the transmission is bone dry like after a rebuild with a new torque converter. If you were going to do a flush, you'll need 15-17qts depending on how clean you want the fluid to be.
scottsleazk
Mar 12, 2015 03:36 PM
bertrenolds
Feb 17, 2011 04:05 PM
TimsR1
Nov 15, 2010 08:53 PM
espencars
Aug 16, 2010 06:55 AM
the fuel
Engine & Internal
Dec 15, 2005 01:25 AM
