quadrajet help anyone
Old Apr 5, 2011 | 03:39 PM
xillzxnickx's Avatar
xillzxnickx is an unknown quantity at this point
Default quadrajet help anyone
i have a quadrajet on a 4.3 yes 4.3 and i recently had it rebuilt and sence then the car runs like cr*p .... at first the car idled at 3000 rpm i played with the choke idle and qot it down to about 2600 rpm but it wont idle it will really slowly work its way down to stall out i played with the mixture screws already and no difference and there not really even screws there these like backward philps screws idk but any ideas on what to do i heard maybe a vacuum leak but just doesnt seem right for it to idle at 3000 rpm
Attached Thumbnails quadrajet help anyone-dd0120b11b31__1302035575000.jpeg   quadrajet help anyone-df2be76b1bca__1302035575000.jpg
Old Apr 5, 2011 | 07:54 PM
Are you sure that all of the throttle blades are closing? No vacuum leaks?
BTW, please try to keep requests for help on the forum. I try to get to every thread when I can and do not need prompting to look at your thread.
Old Apr 5, 2011 | 08:50 PM
jdub9000's Avatar
jdub9000 is on a distinguished road
quadrajets can be the most annoying carbs to adjust but when you have it perfect the will perform just as well as a double-pumper holley.... just as swartlkk mentioned before check and make sure everything is opening/closing and working properly and ther are no vacuumm leaks... once any problems are fixed adjust your idle screws all the way in until it dies and stop IMMEDIATELY.... then turn turn them out just enough to get it to barely run... then count the turns as you turn them all the way out until it dies and stop IMMEDIATELY... now take the number of turns and divide in 1/2 and turn the idle screws in with the number you have and that should get you pretty close to a smooth idle.... every quadrajet is different for every engine so you will just have to play with it (could take all day) until you have it perfect..
Coatchawa
Jun 23, 2015 07:27 PM
84_K5Blazer
Oct 12, 2013 03:12 PM
newguy
Mar 22, 2013 09:36 AM
Toby Hanson
Dec 20, 2011 12:43 AM
oisinirish
Apr 16, 2009 10:06 AM
