question about neutral safety switch
Old Apr 14, 2008 | 05:18 PM
Hanr3's Avatar
Default RE: question about neutral safety switch
In that case your 700R4 TV Cable (not a detent cable) should hook up no problem. You will still need some method to control torque converter lock up, especially if you plan to drive this thing on the highway. Without it, you will fry your tranny.
Old Apr 14, 2008 | 06:48 PM
95_4door's Avatar
95_4door is an unknown quantity at this point
I have the kit for the tcc. I just have to wire it. My tv cable isn't even a problem, right now, the only problemI am having is the neutral safety switch.
Old Apr 14, 2008 | 07:39 PM
Hanr3's Avatar
You could swap the steering column to a pre '95 version and the switch will be on the column. You will need the shift linkage. '95 and later GM started using a cable instead of the old style shift linkage. You just need the parts from a donor truck, grab everything from teh column to the tranny, including the bracket the pivot ball mounts too.
LilPudge666
Oct 12, 2013 08:17 PM
chappie74
Oct 17, 2010 10:42 PM
kship3
Oct 16, 2010 03:24 PM
metcalfr
Nov 23, 2009 01:07 AM
blazerssuck
Dec 5, 2006 08:14 PM
