Question about valves for the P0756 code
Old Jun 19, 2023 | 07:25 PM
cage47's Avatar
cage47 is on a distinguished road
Default Question about valves for the P0756 code
So this weekend I dug under and tried to fix my P0756 code. By going by this diagram:
I went to autozone and they sold me the switch labeled 394. I thought it was wrong and went to oreilleys and got the solenoid labeled 367b. Here's my issue. Intermittently when I leave first thing in the morning I make two stops before getting on the freeway. on my second stop (within a mile after leaving the drive) I get the P0756 code and I find that I am stuck in 3rd gear. I am sure it's third because I can down shift manual. It will go down to 2 and then down to 1. Then I can shift it manual back up to 2. Then to 3. But when I put it in D it doesn't shift. And I find that stopping doesn't help. It is stuck in 3rd. BUT if I stop. Shut the truck off and sit for 10 seconds it is fine. I replaced solenoid 394 on saturday. Went to Texas Roadhouse that night (sore like a truck ran me over) and it drove and shifted good. I went to work today. Again. got the P0756 code. The wires look good and I did the continuity test. Fine. I'm wondering if solenoid 394 might actually have been the problem since it's not DOWNshifting. But once I stop and let it clear it is fine the rest of the day.
Old Jun 23, 2023 | 08:37 PM
cage47's Avatar
Ok I'm a firm believer that you can not call someone else a dumbass if you can't call yourself one when you are one.
So come to find out I got home wednesday and had a code thrown up again. So for shyte and giggles I popped the hood and did a check. I'll be damned. I was still a quart and a half low on fluid. Filled it and these past two days, shifting smooth and no hickups. Will update if this changes but it looks like everything worked out finally.
cavecookie
Apr 28, 2020 08:18 AM
jkfrost77
Oct 13, 2013 08:34 PM
brians1bad72
23
Jul 25, 2010 05:45 PM
loisengleny
Apr 30, 2010 07:47 PM
hambone8
Apr 14, 2010 01:20 PM
