radiator
Old Dec 20, 2008 | 09:17 PM
stevo's Avatar
stevo is an unknown quantity at this point
Default radiator
have had a leak for about a week now, bought some stuff to try and fix it, like a liquid additive, and it worked on one side, and made the otherside leak worse
so i bought a new radiator for 140 bucks and installed it
has anyone else had this problem?
i have a 2001 4dr 4x4
with 103 thousand miles on it
Old Dec 21, 2008 | 01:59 PM
Default RE: radiator
Leaks often happen when radiators are not cleaned as a required maintenance. Junk that builds up on the radiator will cause it to rot and open up a leak.
With the newer radiators having plastic side tanks, these can sometimes open up leaks. This often happens quickly, not something that creeps up after time. A traumatic incident (crash, going into the ditch, etc) can cause a leak though. Even some rough driving with harsh bumps can sometimes open up a leak.
Stinks when it happens, but glad you got it fixed. I have never been a proponent of the stop leak products. If there is a problem, I would much rather fix the problem than put a band-aid on it. But there are some products that do work; Bar's Leak & the pellets from the dealer both meet the manufacturer's requirements which are put in place to ensure that the product does not clog the system once it's in there.
bigdaddykane93
Jan 4, 2010 12:03 PM
FLcruising
Jul 4, 2005 02:51 PM
Blazin 4x4
May 25, 2005 01:57 AM
PawNtheSandman
May 2, 2005 11:15 PM
93blazerman
Engine & Internal
Apr 7, 2005 02:26 PM
