random choke/sputter
Old Jun 17, 2017 | 11:32 AM
freshy187's Avatar
freshy187 is on a distinguished road
Default random choke/sputter
98 blazer 4wd auto (US) here.
while driving at random moments (speed/rpm/load irrelevant) it will seem like it missing fuel n choking it self for a split sec i release the gas pedal it comes back. had one bad enough at 70+ mph that it threw the tach and dummy light came on for 2 sec then came back online. thought bad fuel but im pretty religious on premium fuel at reliable retailers, and usage tech-ron or sea foam.
had a EVAP code pop after car wash about 1000 miles ago but that went away.
no codes currently
new (rebuilt motor) 17k ago/october16
new plugs/wire.cap,rotor, fuel filter(now K&N) with the motor swap.
my first thought is change the Filter again but is it that likely to clog that soon?
Thanks
Old Jun 17, 2017 | 11:44 AM
newguy's Avatar
First thing to do is a fuel pressure leak down test
Old Jun 17, 2017 | 11:45 AM
newguy's Avatar
Old Jun 17, 2017 | 12:09 PM
freshy187's Avatar
thanks for the link well explained ill give it a shot.
Old Jun 19, 2017 | 10:03 PM
freshy187's Avatar
so i tested the both about 11 mins
rail started @ 60psi ended at 40 out of spec
the tank/filter started at 79 ended at 62. with in limits but This seemed to be on the low side of the scale. is this a concern?
which leads me to believe its the FPR.
additionally, Is there a way to check injectors that might be stuck open allowing fuel to dribble? while im in there replacing a FPR?
besides having all the fun of pulling plugs?
dlboyd
Dec 3, 2009 11:09 PM
blazeric
23
Apr 13, 2009 08:01 AM
dlboyd
Oct 25, 2008 06:47 AM
DiRK
Nov 29, 2006 01:43 AM
MsRandi
Jul 10, 2006 08:21 AM
