trans slip after service?????
Old May 29, 2017 | 08:53 PM
bud1's Avatar
bud1 is on a distinguished road
Default trans slip after service?????
kinda sucks this has to be my first post,but... did a trans service to my 99
blazer today with 185000 miles on it. got all done and drive and 3rd seem to slip, but i have good 1st and 2nd + reverse... i can take off in 2nd and get going and then shift to drive and it seems to run alright ,just no take off in drive or 3rd...
thanx for your help.....
Old May 29, 2017 | 10:06 PM
Transman304's Avatar
Did you have trouble getting the pan off at the back above cross member? Breaking a shift solenoid is very common on these.
Old May 29, 2017 | 10:32 PM
bud1's Avatar
it was a little tricky... as you have to let the front down first to drain some of the atf... so if one is bad it may just be stuck in a high gear, like taking off in4th on a manual trans???
Old May 30, 2017 | 05:29 AM
newguy's Avatar
Sounds like the 3-4 pack is slipping, which would mean a rebuild. A lot of times on older vehicles trans fluid changes are not recomended
Old Jun 12, 2017 | 03:02 PM
LesMyer's Avatar
I would definitely check into the broken shift solenoid. Much better than going straight into a rebuild and it makes sense - what else could you do during a service that would cause your problems? I haven't known Transman to be wrong yet. I'm no transmission man myself, but I am able to recognize that he knows his stuff!
Old Jun 13, 2017 | 08:13 AM
Thanks for the kind words Lesmyer! I just like to share my knowledge so people will avoid the pitfalls of just throwing time and money at issues I have come across in my many years. Also I have been wrong many times Just mark it up to a lesson from the school of hard knocks and learn from it. Some cost money some not. And be sure to not do it again. I have learned more from mistakes than any book could teach.
Old Jun 15, 2017 | 08:04 AM
FMB42's Avatar
FMB42 is on a distinguished road
Also double check that you follow the owner's manual to the letter when it comes to checking the ATF level. This procedure is not at all like most other vehicles including older GM stuff. Not following this procedure will almost always result in an 'over-filled' condition that can effect shifting and/or reverse operation. You probably already know this, but I want to mention it just in case.
Old Jun 20, 2017 | 03:27 PM
run_girl's Avatar
run_girl is on a distinguished road
Chirping in here too - I agree with FMB42 on overfilling. That could cause a lot of damage! I'm having the same issues, but I don't think they are transmission related (had the fluid changed and the tranny inspected and they found zero issues). What was causing my acceleration slip issue was my dirty fuel filter. I'd read into that as well because sometimes other issues that seem like tranny issues are not and are related to other things going on mechanically. Just my 2 cents.
badpoor
Jan 7, 2011 06:35 PM
gmbwrenchn
Aug 9, 2010 06:53 PM
98jblaze
Apr 7, 2010 05:49 PM
wayfastwhitey
Apr 13, 2009 07:13 PM
1qazse4
Dec 3, 2008 02:09 PM
