RE; Dropping Pan
Old Apr 20, 2010 | 08:35 AM
kennybopaloo's Avatar
kennybopaloo is on a distinguished road
Smile RE; Dropping Pan
when you are replacing tranny fluid and the filter, do you have to drop the crossmember that blocks one side of the pan ????????
Thanks, Kennybopaloo..................................
Old Apr 20, 2010 | 09:24 AM
You may have to. All depends on what you are working on. At this point, I am not going to look back through your posts...
I didn't have to remove the cross member on my 2000 Bravada. If you force things, you can damage the solenoids on the back side of the valve body which isn't good.
Old Apr 20, 2010 | 10:34 AM
Red face RE; Pan
as i look up a the pan you can see the crossmember just about touching the outer rim of the tranny pan.
it looks like a very,very tight squeeze to get the bolts out.
i presume the crossmember coming down doesn't interfere with anything else. you just drop it and put it back into place.
Old Apr 20, 2010 | 10:04 PM
LowLife's Avatar
LowLife is on a distinguished road
NO YOU DONT JUST DROP YOUR CROSSMEMBER.....that will leave the back of the tranny "with t/case if 4x4" sagging bad! if your talking about the 4l60e trans, No you just use a 1/4" drive 10mm for the shifter link. and 12mm for the rest "im pretty sure on size" then just drop the pan and do whatever you need in there.
Old Apr 21, 2010 | 06:30 AM
Talking RE; Tranny Pan
Thank everyone for their input on the tranny pan.
Kennybopaloo
6Cyl'erThriller
Mar 13, 2012 01:05 PM
JoshuaDeacon
Tires and Wheels
20
Feb 12, 2010 04:33 PM
middleman496
Aug 10, 2007 02:02 PM
vagnozzi
May 6, 2007 01:17 AM
speeddemon560
Suspension Tech
Feb 6, 2007 04:18 PM
