Rebuilt 4.3 leaks oil...where?
Old Feb 27, 2013 | 07:17 PM
tleed's Avatar
tleed is on a distinguished road
Default Rebuilt 4.3 leaks oil...where?
Rebuilt 4.3 in a '96 has an oil leak. If you've pulled one of these engines, you know how tight they are at the back. I don't want to pull this one again. But there's a leak somewhere at the back. At the moment I can't tell if it's the rear main, or from somewhere else. Anybody tell me what the possibilities are? What's likely & where to look? On the plus side on the passenger's side it looks like it's coming from higher up.
-Thomas
Old Feb 27, 2013 | 07:47 PM
chris015's Avatar
pressure wash the oil cooler lines/adapter,or if you dont have those,and u have 4wd,pressure wash the 4wd lines and adapter that mounts to the block. they are prone to leaking and making it look like a rear seal. its only a oring and a gasket
Old Feb 27, 2013 | 08:14 PM
richphotos's Avatar
or... or. just deleting the remote filter housing.
Old Feb 27, 2013 | 08:44 PM
chris015's Avatar
touche. ive done it. your gonna do it...
Op. if u wanna delete the lines,use pf47 filter. its shorter and will fit between the front diff if u have 4x4.
celteagle
May 27, 2014 12:51 PM
nadasade
Sep 29, 2011 12:09 AM
S10Blazer
Sep 30, 2010 04:27 AM
skitzobmxr
Dec 17, 2006 09:57 PM
swartlkk
13
Dec 20, 2005 08:13 AM
