rebuilt motor
Old Jan 5, 2008 | 07:52 PM
fbpatriot14's Avatar
fbpatriot14 is an unknown quantity at this point
Default rebuilt motor
i have a 95 chevy blazer that we put a rebuild in and the motor has horrible gas milealage. It gets prolly 10-12 mpg. the motor is the stock 4.3 and i cant figure why its wulfin down gas. any ideas?
Old Jan 5, 2008 | 07:58 PM
Default RE: rebuilt motor
I would suspect either a really tightly built motor which may loosen up as it breaks in or it is possible that you have an internal fuel leak...
Old Jan 5, 2008 | 08:00 PM
where could the fuel be leakin from inside?
Old Jan 5, 2008 | 08:26 PM
Internal fuel lines or fuel pressure regulator. The CPI motors are known for this type of problem. And It is possible that during the reassembly after the rebuild that the internal lines were tweaked. If they were removed and not replaced, that right there is enough to cause a leak.
Old Jan 6, 2008 | 07:51 PM
Hanr3's Avatar
did you hook up the 02 sensor?
Old Jan 9, 2008 | 05:28 PM
yeah
tim244x4
Sep 9, 2009 10:24 AM
95_Blazer
Nov 12, 2007 10:31 AM
walkingtall
Jan 27, 2007 05:08 AM
khalid_20879
Mar 13, 2006 01:02 PM
Tittlebitties
Oct 14, 2005 12:43 AM
