Removal of engine/trans together?
Old Dec 11, 2014 | 03:01 PM
apriliaRM's Avatar
apriliaRM is on a distinguished road
Default Removal of engine/trans together?
I have a 99 blazer that i need to remove the transmission. Well after looking it over i wanted to pull the engine because it has leaks everywhere. I just wanted to clean it up and the engine compartment as well.
Is it possible to remove the engine and trans as one unit? I can remove the transfer case.
Somebody must have tried this? Anyone have any ideas? Do i have to raise the body? Remove the core support?
I would greatly appreciate someone elses ideas on how to do it once.
Thank you for your time.
Old Dec 12, 2014 | 08:56 PM
odat's Avatar
I don't think you have the room to pull both at once oil pan sits low in these - when I did a crank job in a 97 LS it was tight too get just the engine in and out
Old Dec 12, 2014 | 09:49 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
I put the motor & trans in mine as one unit!, a pain yes......but it can be done....remover the core support , and push it in!!!
Old Dec 13, 2014 | 11:25 PM
apriliaRM's Avatar
odat and 07nhbpsi Thank you for responding.
I have decided I am going to try pulling both together and see what happens.
I think anything that had a hose has leaked on this thing, What a mess!
If anyone has any cheats or things to look out for I am all ears.
Thank you.
Old Dec 14, 2014 | 12:57 AM
InsanePyro's Avatar
InsanePyro is on a distinguished road
I'd take the whole front clip off as one giant chunk
Old Jan 4, 2015 | 04:48 PM
snow man's Avatar
snow man is on a distinguished road
if you do pull both out together please post to let us know how hard it was. i would love to know.
Bobcat13
Nov 22, 2013 05:56 PM
dice11
Aug 26, 2010 11:56 PM
JeremyNYR
Apr 11, 2010 10:45 PM
A5295
Sep 9, 2006 01:42 PM
