Removing the cam ? on 99 Blazer
Old Dec 14, 2010 | 12:28 AM
chevygonzalez's Avatar
chevygonzalez is on a distinguished road
Default Removing the cam ? on 99 Blazer
I finished--at least I thought--the 99 blaze 4.3 engine and it started. I'm my heart I knew the cam could be a problem as I didn't change it. Now I have to pull all the components to get to the cam. I know I must remove the Radiator. I would like to know if the cam can be pulled out without removing the A/C radiator and or grill; Is it too far a pull distance to not remove it? Also, where can I get instructions on the cam bearing removal and installation and tool to do this? Can the bearing fall inside the engine? Engine is on vehicle. Thank you in advance.
Oreman
Nov 10, 2013 09:03 AM
Mark Edwards
Jan 12, 2013 11:32 AM
Xtremechubs
Engine & Internal
Aug 26, 2009 11:10 AM
Dakota_Don
Engine & Internal
Jul 21, 2008 09:14 PM
phantom
Aug 14, 2007 07:38 AM
