removing tranny
Old May 4, 2008 | 09:33 PM
foxtibby's Avatar
foxtibby is an unknown quantity at this point
Default removing tranny
1996 4.3 4wd
2qusetions guys
1st what is the trick to getting the upper 4 tranny bolts out
2nd does the exhaust have to come off for a sucessfull removal
Old May 5, 2008 | 01:07 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
Default RE: removing tranny
either use snap-on shallow swivel sockets and swearlot like I did or remove tranny crossmember and let the tranny sag enough to get the bolts or undo the body at the mounts and jack up the body to give more clearance
Old May 5, 2008 | 06:05 AM
Dropping the transmission crossmember is the way to go. You will still need quite a few extensions and a swivel at the end to get it done, but atleast you will be closer to being able to see them.
ski.dive
Feb 7, 2014 05:18 AM
lunghd
Feb 12, 2012 06:50 AM
beantowner25
Dec 28, 2009 12:28 PM
Annekat91
Feb 13, 2006 07:42 AM
sunnyc123abc
Sep 9, 2004 04:59 AM
