General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
removing rear deflector
Old Oct 6, 2005 | 11:50 PM
Annekat91's Avatar
Annekat91 is an unknown quantity at this point
Default removing rear deflector
There was a post somewhere recently about removing the rear dust deflector blade on the early 90's Blazers. How do you do that? I see two plastic lozenge-shaped things that could maybe be pried off, but I don't want to do it if I'm afraid I might break something. I'd eventually want to put the deflector blade back on. But I might want to buy a ladder or some lumber and secure them to the luggage rack, and the deflector blade would be in the way. Or maybe it could withstand the weight, I'm not sure, I just know it wasn't designed for that.
Old Oct 7, 2005 | 12:02 AM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: removing rear deflector
someone said that he just got the hinges off one that didnt come with the deflector from a junkyard. i don't know if theres a temporary way to do it, im not really sure cause i got a 95 (new body style) blazer.
Old Oct 7, 2005 | 01:08 AM
chevylane2003's Avatar
chevylane2003 is an unknown quantity at this point
you can take the blade off by popping off that plastic cap and removing the two screws on eack side. Now the post that it sets on will still be there. The only way to get rid of them is to change the whole hinges.
If you put too much weight on the wing with lumber and stuff you will blow the back glass as I did.
Old Oct 7, 2005 | 02:21 AM
LoLoS10Blazer87's Avatar
LoLoS10Blazer87 is an unknown quantity at this point
Just pop those 2 plastic caps off and undo the screws, the blade will come right off. As far as the 2 pedastals that it sits on, they're part of the hinges.
Kyle and I discussed that here
Old Oct 8, 2005 | 02:00 AM
Annekat91's Avatar
Thanks so much for everyone's advice on this. Good to know I can pop those plastic caps, undo the screws, and slide the blade out and replace it later. And I will definitely not put any weight on the blade and blow the glass! I might have tried it if you hadn't told me that.
Old Feb 13, 2006 | 07:32 AM
psyco1887's Avatar
psyco1887 is an unknown quantity at this point
what does that rear window defelctor DO anyway?
Old Feb 13, 2006 | 07:42 AM
It directs air over the rear window to keep the majority of the road spray and dust off of it. It really does work.
OxFORD-ZR2
Feb 14, 2018 04:42 PM
cameradude
Nov 29, 2010 02:08 AM
kickme005
Sep 1, 2010 08:06 PM
ebornand
Dec 16, 2009 05:52 AM
speeddemon560
Jan 11, 2007 10:13 PM
