Repeatingly fouling Cap out
Old Jul 15, 2009 | 04:09 AM
Rlee's Avatar
Rlee is an unknown quantity at this point
Default Repeatingly fouling Cap out
As stated in title, I am having an on going problem with fouling out caps on the dist. I ran 2 cheap ones from autozone and then decided to run the Gold Series and it has lasted longer but is now acting like it has a small studder.
Symptoms: With a new cap it runs like a raped ape for a few weeks or so and then it will begin to miss out at partial throttle (10%-25% throttle maybe less), if you contine at that mark it will miss out till it shifts then do the same again after shifting. If you smash the throttle at that point it takes off like a raped ape once again. I have taken a "Fouled" cap off and sanded down the terminals and this fixes it for awhile but will foul back out. This all was after a RR of a Intake Manifold Gasket job. This is on a 00' GMC Jimmy 4x4.
Old Jul 15, 2009 | 06:14 PM
gscrippler's Avatar
gscrippler is an unknown quantity at this point
is the cap carboned up? are the vent holes in the distributor clear ?
Old Jul 15, 2009 | 10:12 PM
versital98's Avatar
versital98 is on a distinguished road
i think the proplem is the cap is still an autozone cap.
Old Jul 16, 2009 | 08:11 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Replace it with a Delco cap.
Old Jul 20, 2009 | 04:26 AM
Rlee's Avatar
Replaced the whole dist. on Thursday. Guess we'll see how it does.
The "points" were all white on the cheap caps and basically shared the same condition on the "Gold" series cap.
Vent holes looked to be fine.
Old Jul 22, 2009 | 01:50 AM
Rlee's Avatar
Still running good. Seems to have fixed it
BigO01
Mar 25, 2011 08:41 AM
1oldK5
Mar 20, 2009 10:07 PM
riverjamie
Dec 28, 2008 06:18 PM
riverjamie
Sep 18, 2007 04:58 AM
fnbutch
May 12, 2007 08:54 PM
