Replace oil pan gasket
Old Jun 20, 2011 | 09:51 AM
snobrd's Avatar
snobrd is on a distinguished road
Default Replace oil pan gasket
1996 4.3 2 wheel drive
I need to replace my oil pan gasket and was told I had to pull the engine to replace it. Anyone know short cuts or any thing I can do short of pulling the engine. Thanks in advance for any info.
Old Jun 20, 2011 | 01:28 PM
Frog's Avatar
Frog is on a distinguished road
No real short cuts....the problem is....there is not enough clearance for the oil pan to drop down far enough to clear the oil pick-up tube...it will hit the crossmember.
You could just disconnect the motor mounts, trans mount and necessary coolant hoses and lift the engine high enough to clear and get the pan off. But, pulling the engine is the best way. Sorry.
Old Jun 20, 2011 | 08:06 PM
snobrd's Avatar
Default Thanks
Thank you for your reply.
Old Jun 20, 2011 | 08:18 PM
abig84's Avatar
yeah i just checked alldata and it dont tell you squat. heres what you got
Remove or Disconnect
  • Drain the engine oil.
  1. Engine from the vehicle.
  2. Oil pan bolts, nuts, and reinforcements.
  3. Oil pan.
  4. Rubber bell housing plugs.
  5. Gasket.
Old Jun 21, 2011 | 09:09 PM
96blazer191k's Avatar
96blazer191k is on a distinguished road
Default a little more work... sorry
I read up on doing this as well and found that you also might need to remove the timing chain cover and oil pump in the process and also the front axel mounts. it makes the job go from insane to do-able.
Old Jun 21, 2011 | 09:49 PM
Frog's Avatar
The timing cover should not have to come off (it might though each case is different)....the gasket should lay on the bottom side of it.....as for the axle mounts...its a 2wd..I don't think that will apply here.
Old Jun 23, 2011 | 12:05 AM
abig84's Avatar
so basically unless the thing is pouring oil out leave it the heck alone. i always wondered if you could always just drop the pan and silicone the hell out of it and rebolt it back up and get away with it
Old Jun 23, 2011 | 12:23 AM
chris015's Avatar
^ worked in a 1500 truck i had...
for 2 weeks...then got worse....lol
Old Jun 23, 2011 | 03:03 PM
Frog's Avatar
It will work if you get everything nice and clean. I used Honda Ultra Flange II Sealant on my oil pan for my honda (of course) instead of a new gasket and it worked great. Now I use that stuff instead of regular silicone...it is good up to 400F or 450F and it has never failed...but, the down side is that if you ever have to take the oil pan off you will more than likely bend the sides.
Old Jun 24, 2011 | 10:28 PM
abig84's Avatar
thats what i figured. id spray the heck out of it with break cleaner for a hour then wipe it then let it sit for a few day. if the motor is a turd, can always jb weld it
marcspector
16
Oct 23, 2015 09:26 AM
Akira2008
Dec 23, 2010 07:22 PM
kevin turner
Apr 9, 2010 01:21 PM
AaronGene02
Jan 24, 2010 11:38 AM
kakn
Jan 14, 2007 01:18 PM
