-   -   Replaced Battery Now truck won't start (https://blazerforum.com/forum/engine-transmission-35/replaced-battery-now-truck-wont-start-79014/)
chz99 May 2, 2013 10:22 AM
I recently had the battery on my '96 Blazer 4x4 go dead. Got a new battery in and now it won't start at all. Interior and hazard lights blink for a minute or two when I first get in but truck will do nothing to attempt to start. Keys don't get locked in the column. I tried looking up the answer but have gotten nowhere. Any help? Thanks.
coolasice May 2, 2013 10:52 AM
hate to ask, but polarity on the battery correct? + to red, - to black.....
chz99 May 2, 2013 11:01 AM
Just went to double check. Yes, polarity is correct.
newguy May 2, 2013 11:11 AM
Check the fuses under the hood or dirty terminals maybe
coolasice May 2, 2013 11:27 AM
if you turn headlights on do they work?
chz99 May 2, 2013 11:37 AM
Headlights work radio turns on wipers all acc. work. Seems to maybe be some sort of anti-theft system? When I put the key and turn to on position the radio lights blink bright then dim and my hazard lights flash in time with the radio lights. I don't have a FOB and my truck was purchased used so I don't have any sort of chipped key.
coolasice May 2, 2013 11:45 AM
got a multimeter? check voltage at battery
chz99 May 2, 2013 12:09 PM
I don't have a multimeter. It's now started a beeping noise at the same time as the lights blinking.
coolasice May 2, 2013 12:35 PM
you need to trace the power from the battery to be sure you have power at the ignition switch and coming out of the ignition switch when needed. a multimeter is a huge help with this. beyond that someone else with more experience in this may chime in. (if i remember right the earlier 2nd gen blazers had ignition switch problems)
chz99 May 2, 2013 01:03 PM
On my way to buy a multimeter now. Where do I need to check other than at the battery.
