Replaced Battery Now truck won't start
Old May 2, 2013 | 10:22 AM
chz99's Avatar
chz99 is on a distinguished road
Default Replaced Battery Now truck won't start
I recently had the battery on my '96 Blazer 4x4 go dead. Got a new battery in and now it won't start at all. Interior and hazard lights blink for a minute or two when I first get in but truck will do nothing to attempt to start. Keys don't get locked in the column. I tried looking up the answer but have gotten nowhere. Any help? Thanks.
Old May 2, 2013 | 10:52 AM
coolasice's Avatar
coolasice will become famous soon enough
hate to ask, but polarity on the battery correct? + to red, - to black.....
Old May 2, 2013 | 11:01 AM
chz99's Avatar
Just went to double check. Yes, polarity is correct.
Old May 2, 2013 | 11:11 AM
newguy's Avatar
Check the fuses under the hood or dirty terminals maybe
Old May 2, 2013 | 11:27 AM
coolasice's Avatar
if you turn headlights on do they work?
Old May 2, 2013 | 11:37 AM
chz99's Avatar
Headlights work radio turns on wipers all acc. work. Seems to maybe be some sort of anti-theft system? When I put the key and turn to on position the radio lights blink bright then dim and my hazard lights flash in time with the radio lights. I don't have a FOB and my truck was purchased used so I don't have any sort of chipped key.
Old May 2, 2013 | 11:45 AM
coolasice's Avatar
got a multimeter? check voltage at battery
Old May 2, 2013 | 12:09 PM
chz99's Avatar
I don't have a multimeter. It's now started a beeping noise at the same time as the lights blinking.
Old May 2, 2013 | 12:35 PM
coolasice's Avatar
you need to trace the power from the battery to be sure you have power at the ignition switch and coming out of the ignition switch when needed. a multimeter is a huge help with this. beyond that someone else with more experience in this may chime in. (if i remember right the earlier 2nd gen blazers had ignition switch problems)
Old May 2, 2013 | 01:03 PM
chz99's Avatar
On my way to buy a multimeter now. Where do I need to check other than at the battery.
