Replaced Battery Now truck won't start
Old May 2, 2013 | 01:12 PM
erikander's Avatar
erikander is on a distinguished road
I am going under the assumptionn that everything worked fine before the battery went dead. that being said.... I think you may have two issues here. First sounds like there MAY be some type of aftermarket alarm installed. You can pull the drivers side hush panel then the knee bolster and see if this is true. If so, I recomend removing the alarm and reconnecting any wires the were cut for the alarm. Second thing I would check is to see if you have corrosion on the starter battery terminal. Back in the day, I had a Blazer come in with a simular complaint,I found corrosion linking the battery cable to the starter casing which is grounded. There is enough resistance in the corrosion so it will not burn up the cable, but it will draw enough power to keep the starter from turning over. If you do find this, disconnect the battery and charge it, it probably will be dead from the draw. clean the terminal or replace the cable if needed. clean the starter terminal, reinstall and test.. Hope this helps.
Old May 2, 2013 | 01:27 PM
coolasice's Avatar
coolasice will become famous soon enough
probably should have asked before but why did it need a new battery? and is the replacement new or used?
Old May 2, 2013 | 02:41 PM
chz99's Avatar
chz99 is on a distinguished road
Was an old battery. Stopped holding any charge whatsoever so I brought it in to an auto store they checked it and said it was dead. Definitely starting to think its some aftermarket alarm. I know I'm naive but any ideas as to what I should e looking for?
Old May 2, 2013 | 02:45 PM
coolasice's Avatar
remove the knee panel, look around for a box with a bunch of wires that doesnt look factory
Old May 2, 2013 | 03:08 PM
chz99's Avatar
Old May 2, 2013 | 03:25 PM
coolasice's Avatar
Originally Posted by chz99
Is this it maybe? Welcome to Flickr!
yup, looks like a remote start unit
Old May 2, 2013 | 03:29 PM
coolasice's Avatar
black widow car alarm/remote start unit
srarch google for bw2800, you will find info about it
Old May 2, 2013 | 03:52 PM
chz99's Avatar
Many thanks y'all greatly appreciated. Hopefully removing it will fix everything. Thanks again.
Old May 2, 2013 | 04:40 PM
coolasice's Avatar
more then likely it has something to do with the alarms starter disable...
walleyehunter
Jan 10, 2014 07:44 AM
Sandman_3
Sep 18, 2011 01:21 PM
drew_fur
Jun 8, 2011 03:52 AM
Dan R
Oct 12, 2010 09:12 PM
95Jimmy
Oct 4, 2009 07:21 PM
