Replaced spider injector, still have a #1 misfire with injector circuit code
Old Nov 3, 2019 | 08:34 PM
Dis4Wurk's Avatar
Dis4Wurk is on a distinguished road
Default Replaced spider injector, still have a #1 misfire with injector circuit code
Been having issues with my ‘01 blazer. First it threw random cylinder misfire with a MAF sensor, replaced the MAF, then came the cylinder 1 misfire, diagnostics and troubleshooting pointed to the injectors (I still had the old style), replaced injectors with upgraded version, now the Mia is slight, only below 1500 rpm, but still throws a cylinder 1 code and a new code p0200 injector circuit. Have checked the plugs, wires, pins, connector, harness, used the noid light, everything seems fine. What is my next troubleshooting step or what am I missing? Also, I don’t know if it’s relevant but my mechanic thinks but the piston rings are letting oil passed and the egr is sucking the vapor and recirculating it to the i take, the thing was covered in oil and carbon when we changed the injectors yesterday.
Old Nov 4, 2019 | 11:11 AM
LesMyer's Avatar
Bent or loose pin in injector connector (open)- or wiring harness melted (shorted) on the front of passenger exhaust manifold or A.I.R.check valve tube. Mine was melted on check valve tube after I misrouted the wiring harness after engine replacement.
good luck
whymyblazer
May 19, 2013 09:22 AM
bluchian
May 13, 2013 08:49 PM
tim68
Feb 6, 2012 02:44 PM
chevychallenged
Apr 5, 2011 07:20 AM
jmatt07
Dec 18, 2009 09:48 AM
