Reverse and Neutral don't work after flex plate install! HELP please!
Old Dec 23, 2011 | 02:44 AM
younger1993's Avatar
younger1993 is on a distinguished road
Default Reverse and Neutral don't work after flex plate install! HELP please!
Hello I replaced a flexplate on a 1994 5.7L blazer with an automatic transmission. I removed the transmission, drained the converter, replaced flex plate, torqued everything to specs and put everything back together correctly.. Park, overdrive, drive, 2, and 1 work as they should. However reverse just puts the blazer to a stand still, and neutral moves the car forward like overdrive, and drive gears..after driving around for a bit the fluid level is full..
When I filled the transmission, I added fluid while the car was off, and then topped it off while the trans was in park after it had been running. If anyone has any ideas on whats wrong that would be greatly appreciated!
Old Dec 23, 2011 | 06:33 AM
TZFBird's Avatar
TZFBird is on a distinguished road
So what happens when you put it in Park? I make sure the transmission is in Neutral when I pull it and the shift indicator is in Neutral. Then upon reassembly it just needs to be in Neutral again. If my memory is correct you probably had to shift it out of park to remove the shift cable from the linkage on the transmission. That is most likely where your problem started. The transmission shifted however the cable and lever in the vehicle did not.
Old Dec 24, 2011 | 07:50 AM
I would look at linkage, however, I hear and see the trans shift from park all the way to 1. I know the parking mechanism in park at the output shaft is engaging because I can hear it. Engine feels loaded when I throw it into park.
Old Dec 25, 2011 | 08:40 PM
reamracing#08's Avatar
reamracing#08 is on a distinguished road
bad pump in tranny
Old Dec 26, 2011 | 11:30 AM
Originally Posted by reamracing#08
bad pump in tranny
Would there be a way to check this?
Old Dec 26, 2011 | 03:11 PM
chris015's Avatar
Are you sure you seated the torque converter all the way?
guitarranger11
Jan 17, 2012 11:06 PM
96jimmyslt4x4
May 29, 2011 03:55 PM
DetailersDomain
Detailing
Feb 19, 2011 07:30 PM
dillon
Jan 13, 2011 09:55 PM
JimmySLS
May 7, 2009 06:41 PM
